Hi 23,Probably, but go very gentle to try and keep the plinth bricks as they are, pointing colour/style will inevitably not quite match, so be less visible if the plinths aren’t redone
Hi J,Out of curiosity, why are you replacing them?
Don't forget, you have brick 'specials' on those returns.Hi,
I may have to replace the spalled bricks shown in the photo.
Is it safe to remove them all in one go? It's below a bay window.
CView attachment 421113
Hi W,Do half first, then the other half.
That mortar looks really strong, which may be a reason for the spalling. But it may be just more recent repointing and, the mortar behind softer.
If the whole joint is hard, this means that you should be careful with banging the wall. Try and cut out as much as possible with the disc or if feasible repo saw and tungsten/diamond blade. Otherwise keep a sharp chisel as the mortar may be strong but brittle and tends to snap away from the bricks
Hi N,Don't forget, you have brick 'specials' on those returns.
You will expose the 'core' of the brick and lose the weathering face. Not a good plan.Hi N,
I plan to cut the angle on ordinary reclaimed bricks that I have.
C
That's the cause of the spalled bricks then.Hi W,
The rest of the house is lime mortar, so I suspect the hardness is recent pointing, so no problem
C
Cut the joints with a hand saw thenHi W,
C
