Plug in solar
Yes very likely the case, but as I had said, plug in is not installed, so has to have different criteria like you can't ask for a copy of the installation certificate.
I disagree, you have to mount the bracket and fix the PV's to that, for one. There more to it than plugging it in.
Well if i do a lighting circuit or two in my home but instead of wiring directly into the consumer unit and fed from from a 5A or 6A MCB or a 5A fuse I put a plug on it and connect it to an existing socket then is it fixed/permanent/non permanent the how would you or how could you classify that? same or different?
It could be unplugged but the rest of the installation would be fixed/permanent? Is that relevant to plug in solar?
is it or not? i could see it being agued either way according to the viewpoint of the person, the definition of that person or the definition of the ruler makers ? they might or might not align
It's fixed, of course. Permanent/non-permanent are not relevant.
Unless that person is authoritative in the context of defining regulatory terms, then their viewpoint or definition is irrelevant.
All words mean either what dictionaries and accepted commonplace definitions say, unless they are given a specific definition by a regulation or law, or via a court ruling. Any "misalignment" is of no importance.
