Texecom Wintel connection error - working yesterday, not today
12 Jul 2017
Somerset
I kind of broke my Texecom install a while ago after an update (I even found a post I'd done about it here) think I fixed it way back when, and then just ignored it and the alarm fell out of use.
I read somewhere recently that it's actually compatible with Home Assistant (HA), so yesterday, after realising the old laptop I'd used to manage the "site" previously was dead, I got a Windows 11 virtual machine to connect to my Premier Elite 24 through the ComIP, created a new site and pulled all the info from it, so I was reasonably happy that I could manage without the old dead laptop.
I even figured out how to get it all working with HA using the same UDL password, IP and port as Wintex was happy with. Great.
The three ricochet sensors in outbuildings were waaaay out of power from the batteries, so switched those out this evening, thinking I could re-pair them again once I'd figured that out.
Fired up Wintex again and it's having NONE of it. "connection with control panel could not be established" using the same settings as it was happy with yesterday. In fact, arguably, the HA server is also using the same details, and that's still reporting on the sensors with no issue, so I feel perhaps it's Wintex being silly.
Any ideas?
I've been through and checked the IP is the same, port etc, on both the keypad and the software. Latest version of Wintex (which looks like it belongs in 1993 still I see).
Thanks for reading.
Hard to say for certain.
But coms, are such you can’t communicate out on a comport and connect in at the same time. So use another com ip on a separate comport should help take that possibility out of the equation.
I bet it's exactly that! Forgot that fact, and did vaguely remember that being the case too. With the Home Assistant being connected it'll be that for sure.
If I can be bothered, I'll drop that connection and try again. Was only to get the ricochet stuff working, but don't need the computer for that I guess, just learn them at the keypad I suppose.
