I do miss EFLImpudence he made some good points, I especially like this one to morqthana.
I didn't say it was I just said I liked someone else's comment.
Such stupidity.Not at all.
I would not be surprised to learn that what you remember is being shown that the regulations don't say what you want them to say.
So how do you connect a cable to a blanking plate accessory?
Such stupidity.
Just screw a connector block into the back of the metal backbox and suddenly it becomes a junction box and all of a sudden it's perfectly acceptable.
If we saw one of these in the middle of a wallView attachment 422866Nobody, not even Flameport or mister Mindy would give it a second thought, why anybody questions a perfectly normal electrical accessory I don't understand.
What question are you actually asking here,Would the cables be connected to a point, accessory or switchgear on the surface of the wall?
My interpretation of your question is requiring surface mounted devices,
That's the problem, the group of us in DM's don't know what it actually says.Seems pretty straightforward. What does it actually say?
So would the blanking plate not be on the surface of a recessed box?Sockets, switches, FCUs, etc are on the surface. The boxes enclosing the connections may be recessed, but the accessories are on the surface.
Well you can't have it both ways, either the socket is on the surface or recessed - either the blanking is on the surface or recessed. You can't pick and chose which you want it to be, the socket and the blanking plate are mounted on a recessed box in identical methods and any definition for one applies to the other.So the question "Would the cables be connected to a point, accessory or switchgear on the surface of the wall?" is meaningless to you?
OK.
I'm afraid I can't think of a way to simplify it for you.
Does that quoted regulation talk about a point, accessory or switchgear on the surface of a recessed box, or a point, accessory or switchgear on the surface of a wall or partition?
But suggestions have been made to convert it to a different accessory...Apart, that is, from the little matter of whether something has cables connected to it.
A socket has cables connected to it
A blanking plate does not have cables connected to it. For how long do you think you will carry on pretending that it does?
Why don't you read the thread yourself?And what different accessory/ies have been suggested?
