EICR results question
To find the suspect socket, I would simply plug in my loop impedance tester, and one would quickly find at least area of the fault, but although easy for an electrician for a DIY without the loop impedance tester, this would present a problem, so question is with comments made, is he an electrician?
On a small ring like this would a loop test reveal much?
The electrician did the test and left.
I see the report & see on the quote how long apparently it’s going to take.
I’m keen to look do it myself and to not lay them.
Hence why I ask if there is a toll so when I plug in I know which socket it is without doing all of them.
Then one less job for him.
There isn't a plug-in device that can help with this.
In principle you can use a multimeter to measure the resistance between earth pins from one socket to the next, but the difficulty is that these resistances are all rather small - multimeters don't have much resolution at those values - and you will probably need long leads. If you have a multimeter and would like to try anyway, let us know and someone will suggest what to do.
Seems excessive time 2/3 hours as there isn't many sockets at all
If there aren't very many, you could have just done it by now.
Even if it really was 2-3 hours work, you could have just done it by now.
