Hi all.
I have used flexi pushfit with isolating valves for a wash basin and unfortunately the end that connects up to the supply pipe is leaking.
B&Q say they can not be removed. The only thing is that they cost 8 pounds each and i wouldn't like to cut the pipe. Any suggestions as how to recover it?
The pipe was cut square with a pipe cutter and cleaned. Would you smear a bit of washing up liquid round the pipe next time and then push it firmly into the fitting with a twist to make sure it fits properly? Thank u 4 your advise.
