Best tool to cut copper pipe against wall
21 Mar 2011
Leicestershire
Can anyone recommend a tool to cut copper pipes with only about 10mm clearance from the wall?
It's for my bathroom basin, which I want to replace. The original isolation valves and flexi pipes seem corroded, so I'm thinking of cutting below to clean the copper. Then, I can use compression fittings and a new isolation valve to attach the new flexi tails. Thanks
