When terminating SWA into a plastic adaptable box, is the norm to fit the banjo on the outside of the box, or inside? The box is external (IP65) It is two core swa cable, the armour being used as the CPC. Intention is to use brass M4 nut bolt washer and a crimped ring lug from above to choc block (joining to T&E and then onward to CU)
EDIT: Thinking about it if the banjo is ouside then it will have a better connectiion to the armour as it will be trapped against the brass of the gland, as opposed to inside wher the electrical contact would be just the thread of the locknut, right ?
