The electrician left earlier after doing the CU change and adding 3 new radials for hob and 2 ovens. Until the new kitchen is fitted I aim to re-fit the old cooker to allow us to eat something other than Fish and chips.
Just taken the cover plate off and electrician has run the cable into the lower part of the cooker plate which seems odd. Withthe 4mm it's probably OK, but I can't get two 10mm cables in the same connector and secure the cable in the cable restriant. I had expected the radial to run into the top of the choc connector and the hob/cooker/oven to run to bottom. Am I missing something? Picture of cooker plate below. This is the 4mm, as it's easier to see how the radial has been run in.
