Well, I'm going to be last.
not really mate.personally i would forget all about that jb business and take a feed from the last light of the circuit you are tapping into run through a spur after that to feed all the lights.that way you only end up with 1 end of line and not 3.if your going to all that trouble though why not run a new cct?A couple of months ago I installed an outside security light. I inserted a junction box into the feed to the shaver socket in the bathroom and ran a spur to a FCU and then outside to the light.
I now, want to add a further 2 lights (only 150W each). What I was thinking was taking a feed from the junction box above, taking this to a FCU and then onto a 2nd junction box which will feed both my new lights.
Does this sound ok to do?
surely not!
lighting will go on the non rcd side if you have this type of board.
i answered this earlier mate.plenty of people have had input also and from some of the better posters.dont you trust my answer?Anyway, as said several times RCD is not required.
So, is it ok to do what originally asked?
