Depending on the make there is usually a lever at the side which can be used to manually open the valve and a slot to rest the lever into when its opened.
Depending on the fault, doing that does NOT usually operate the switch to bring on the boiler!
Tony
PS "Diverter valve ?" was meant to mean that it sounds likely to be a failed diverter valve ! Next time I will write "failed diverter valve?" !
Tony
