moving an electric cooker
22 Dec 2007
Essex
hi guys
i'm fitting a new ktchen which means i have to relocate the electric cooker.
i have the correct cable, socket and connecting box thingy.
my question is: can i take another double socket from the cooker point as i only have 2 double sockets in the whole kitchen? (apart from the cooker point) and can i wire the extractor hood thingy directly from an existing double socket? it will have it's own switch.
i hope someone can help!
penny :?
hi guys
penny :?
far more info required penny.
are the sockets on a ring main and not just a spur spur spur type arrangement that we see all to often?
is the main bonding up to scratch?
how are the circuits protected?
can we have the wattage of the oven?
not trying to do you down but this work is notifiable and may be better left to a sparks.
going out now but others may help!!!!
the sockets are on a ring main
as far as i am aware the main bonding is up to scratch
the circuits are protected by individual circuit breakers in the consumer unit. ie one for cooker, one for ring main etc.
the cooker is 50HZ
i've tried to get a sparks but cannot find one for love nor money!
penny
going out now but others may help!!!![/quote]
Then you may add an FCU for the hood.
What did you find when you checked?
So you've got a dedicated cooker circuit, so you can't put sockets on that.
the cooker is 50HZ
That's the frequency of the supply, not the wattage of the cooker.
You'll have to notify the work then, if you care about the legalities.
How do you know it's the right cable?
When you say socket, I assume you mean the cooker control unit? Have you also got an outlet plate?
"Connecting box thingy" - ideally you should replace the cable with a longer one, not join it. What rating is the junction box? Where will it go (it mustn't be buried in plaster/behind tiles)?
that's great - thank you
can you explain what exactly "the main bonding" is as i'm not quite sure.
ok - that's what i thought
the cooker is 50HZ
label on cooker says volts 240, heat W 11450, motor W80, AC only 50HZ, total W 11583
how do i notify the work?
have bought junction box 45/250, cooker point 45 amp with 13 amp socket.
cable 47A surface mounted with cable clips. this will be behind base units and in a conduit from there to switch.
what is an outlet plate?
ideally i would re-wire from the consumer unit with one new length of cable but this would be diffficult as it goes through walls and concrete floors. i asked at an electrical retailers and they said it would be ok to connect using the junction box above. is this correct?
it all depends on the size of cable feeding the cooker switch,the wattage of the oven and the size of mcb.
without this info we could,through cyberspace,set fire to your house :lol:
the cable is 47A
wattage of the oven is 11583 (it says W next to it so presume this is wattage)
what's an mcb? is that the circuit breaker thingy?
the switch is 45A with 13 A socket. what's an outlet plate?
don't want to set fire to the house :?
