ACL lifestyle Mid Pos Valve Leak, help please?
31 Dec 2007
Cheshire
Hi All,
This is my first post - and first problem in my first home!
I have an acl lifestyle Mid Pso Valve 679H340-30L0 and where the black adjuster switch is located it keeps on leaking - by this i mean dripping when the heating and hot water are on - its not gushing out but enough to cause me concern. (probably collected about 20ml today)
Not knowing anything about CH - is this some sort of relief valve and therefore normal - or does it need replacing?
I have the water set at a temp of 75oC - which i reckon is a bit too hot?
Any help will be greatly appreciated.
James
thanks, i am not sure how long it has been like this,
do they cost much to replace? is it worth me taking out some insurance on the CH and have it replaced under that?
also it was on the W setting - i have now moved the switch to the 'M' setting - could that help or am a clutching at straws here?
W= Hot water Only
M= Both Heating and Hot Water
H= Heating only
Its leaking and needs to be replaced
end off
and the are about 50 odd quid
so is that £50 by a plumber?
I have no clue with plumbing so I dont think I'd like to try it unless I am looking at a hefty bill?
No for the part
as for how much someone would charge you I have no idea, call around
is it simple enough to do? is there a guide on this site?
sorry to be a pain its just time od year and all , no money and i don't want to be getting wripped off by a plumber!
Go and buy one you will need the ful thing,just check it first,turn c/heating main switc off,by boiler it hould be then undo 2 screws on valve head and lift off and you should see if the glands have gone
Yes you are right ALL plumbers rip people off
There are no exceptions ALL plumbers hang around just waiting to empty peoples bank accounts.
Most plumbers after they have charge you the equivilant of your mortgage for a job that a Monkey could probably do (lets face it plumbing is the easiest job in the world, for gods sake Kids can do it) they usually then grab you by your ankles, turn you upside down and give you a good shake to ensure that they have all your loose change too.
Honestly ALL tradesmen are low life scum and the plumber is the daddie of them all
Sheesh
It should not be a big job and most plumbers could probably complete it within the hour if they dont have any problems refilling.
If you dont have a clue I think it would cost you more to DIY rather than allow a Plumber in your house even though he will probably nick your telly THE SCUM
Dont bother doing this
You have water coming out of course the glands are leaking
Come on alan
:roll:
corgiman - apologies if i caused offence - its just i know a few people who have had bad experiences, incidentally i was not saying i would have the wool pulled over my eyes just that the hourly rates charged are a little steep when you have no money! :lol:
petit_pablo/corgi man i guess there is no chance of the glands being replaced? :?
