It all depends on what the legal definition of Competent is doesn't it? We all think that we are competent but the ACS and Corgi registration proves that we are competent to work on gas appliances that we have a module in... It does not prove that we know how to fix stuff, simply that we can do the work safely and can work to the legal requirements. Therefore if you have not passed your ACS and are therefore not corgi registered for the type of appliances that you are working on, or gas being used (in my case LPG) then you are regarded as "Not yet Competent"
but surely changing a pump or pcb isnt going to blow the boiler up ? is it . then again my local garage says only a trained mechanic should change brake pads !
