BAS, splitting hairs seems to be a forte. Perhaps my syntax is off sync with the way you like............
The fused spur provides the on/ off facility to prevent 3rd party abuse of the external socket, which would otherwise be permanently on.
It also allows some derating since a range of fuses can be supplied between 1 amp and 13 amp- which although not required is still a prudent safety feature.
Regarding the RCD not being in place and a need to protect the whole circuit or just the external circuit.
* Best practice would be to apply an RCD to the whole of the circuit, an RCBO costs about £45.
* A change over of CU to split will cost £300>++
* A RCD external socket is £65 against a non RCD external socket costing £25
Given the choice, full circuit protectionvia RCBO is a value item due to the potential for other sockets to still have extension lead run from them, say at the back of the house for the lawnmower. An external RCD socket will fail due to moisture and ambient conditions far quicker than a RCD in a CU in a dry environment.
So protect 1 external socket at £65 or protect all circuit sockets for £70 (£25 external socket + £45 RCBO), on materials it really isn't rocket science, is it?
