- Joined
- 29 Mar 2005
- Messages
- 178
- Reaction score
- 0
- Country
I've replaced my CU with a 17 way Wylex split load and notice that there are some numbered sticky labels that came with it. The note said that they're to be stuck on each breaker.
What are the rules regarding this?
If I put number 12 on a particular breaker, does this mean that the earth for that circuit is meant to be in the earth bar terminal number 12 and similar for the neutral? I can't see how this would be possible in my unit because although the earth bar has terminals labelled 1 to 17 plus a few others for the MET the two neutral bars have 1 - 12 and 1 - 15, ie none numbered 16 and 17.
I've made the connections in the same order as the MCBs are in and have labelled each breaker on the outside cover but so far no labelling inside.
