S
saxondale
Hey - denford, saxondale and europlex - thanks for all your help with my project so far.
I've connected up a remote keypad, a PIR and an external box, then powered up my GardTec 816 panel. Luckily for me, the engineer code has been reset to 1234, so I was able to stop it making a noise.
I have a couple of further questions...
1. There's a remote keypad tamper error, even though - the lid is closed, so I'm not sure why this is. There's four jumpers to tell the control panel which ID they keypad is. What configuration of jumpers to I need to tell ID number 1?
put the link on the pins labelled 1 - stretch the spring a little too, check the keypad options that only 1 is selected
2. The second problem is a zone expander tamper error. On top of the main board there's a zone expander plugged in. Although it's plugged in, there's no wires going from this to the main board - is this right, or are these additional connects for when you want to use a zone expander, but don't want to plug it directly onto the board? As well as the tamper spring for the main control box, there's also a smaller tamper spring that goes through the zone expander board. Does this do anything, or does anything have to close this switch?
programme the zone expander off if your not using it
3. When I finally connect up the PIRs, what configuration of wire colours is it best to use, or do all alarm companies use different configurations? I guess it's best to use red for +12v and black for -12v, but what about the tamper and alarm colours - or do I just use whatever I like, then stick to it for the whole installation?
use whatever you like - just make a note for future reference but I would consider using EOL resisters too
you got the manual ?
