cheers for the advice guys,
I will reconnect the room thermostat. will probably replace it with a newer digital one, i expect its not that accurate is it?
Yes, the rad in the hallway has a thermostat on it, and there isn't one on the upstairs landing, as you say, its probably not sufficient to heat the hallway.
Should I just turn the hallway rad thermostat up to full then, to allow the hallway temperature to be controlled by the room thermostat?
