yes it will be hotter, mats reqd, copper pipe, fittings, controls, cylinder & storage tank or unvented unit
and more importantly an installer that knows what there doing.
In the only documented cases of this happening, the cold storage cisterns (not "tanks") were incorrectly installed. It isn't a concern most of the time....and the plastic tank can become full of boiling water, collapse and scald kids to death.
Not so.One was fitted correctly.
You can keep your existing boiler and still use it to heat a hot water cylinder.
Quite a few mupties dont know how to do that but anyone competent will have no problem.
Tony
You really are thick Drivel, the high flow combi's you are recommending are UNVENTED CYLINDERS,
Look at the Ethos 54C combi.
So what has the Ethos got to do
I never said it was, I said your recommendations to others of the Vitodens 333, The Atmos Multi and the ACV Heatmaster contain unvented cylinders, but you did not realise they were unvented did you.
I do know that. It is the choice of the buyer. They know they are. They can get blown up if they like or buy a combi which doesn't.
The ACV HeatMaster can be vented.
"They can get blown up if they want", firstly not a single installed unvented cylinder has ever exploded
They have. ..and they can. Anyone with simple knowledge and common sense can see that can blow up when all fails. You can't That is sad. If you can't identify dangers, then try another trade.
