Help please
living near the end of a very long overhead route, the supply has been very good over the years considering.
However , recently, at odd times, when pluggin in a high power device ( 3kw heater ) the trip is activated. At other times the devices work OK.
Am I right in assuming that its a current problem, where 60amps feed to the property is being affected by high usage elsewhere (unknown) and the current to the house drops to around 15amps or so, thus inducing the trip switch activation when a higher current is required?
Is there a device that I can plug into a mains plug which measures the current amperage?
