hi I have recently purchased 3 power amps - they are each app 2000w each - the manual says they are rated at 1800va & 2730va &
each one has 16amp fuse built in.
they have been fitted with ceeform (blue) ends
I need to know:
1. how to wire the ceeform to mains plug/adaptor together (ie female to 240v mains plug) & recomended cable thickness & type
2. why on a 13amp socket the internal fuse (at the amp) from the mains is rated at 16amp (do you need a 16amp fuse at the plug/mains end?)
3. app they draw a lot of current when powering up, is there something i can put between the mains socket & the ceeform connections to help it not activate the trip switch at the fuse box? (ie a transformer etc / that will stop it drawing to quickly off the mains)
any help would be great
cheers
I need to know:
cheers
