You could but there must be a spares place not far from you !!
Do a search on google ?
Be careful if you do do it coz the wires to the micro switch are live at the end of the day![]()
Arf arfBe careful if you do do it coz the wires to the micro switch are live at the end of the day![]()
So if you try it in the morning you should be ok.![]()
Yes you can push the microswitch lever yourself. The boiler should come on - let go and it should stop.
Not if the diverter is faulty !!
Why not play safe and replace the diverter ?
Heavens to betsy and back again, you could have changed the diaphragm in the time it takes to read this thead!
The diaphragm operates the diverter which operates the switch, see?
When .you have it stripped give both pins a clean with wire wool to clean tiny bit of scale on them then grease with silicone provided in kit.
