what you are suggesting is a very dangerous thing to do and you shouldnt really suggest such a thing on a diy forum.No id expect continuity but that still doesnt mean only one cable at each socket there are two physical cables at each socket in a RFC, count them if you dont believe me.
obviously if you look at the socket there are two cables.the point that some are trying to make is this.
although you have two physical cables at the socket,the effects when connected and energised,are as one.
if you take a brown out of a breaker and re-energise the circuit and grab that cable,you will get a belt.check if you dont believe me,if your not shaking to much afterwards,then you could reply with something less patronising.
afaict the reg is aiming for you to have two individual conductors when they are smallish sized to remove the risk associated with the loss of one of them, the chances of losing both have got to be a lot less than losing just one.although you have two physical cables at the socket,the effects when connected and energised,are as one.
Its quite simple really Bas you have two lives two neutrals and two earths at every socket in a RFC
Does that mean that a radial is the same as a ring, apart from the last socket?Bas its two cables in each socket bar the end one, that makes it a radial
Sorry - I forgot your first post.Ban perhaps you are thinking of what is termed a radial circuit which has one wire of each L(Live) N(Neutral) E(Earth) whereas a RFC has two of each at each socket.
Won't my friend have to remove all of my sockets to show me? I'm worried about the amount of work involved for him...Although I dont suggest you attempt it yourself but if you have a friend whose an electrician get him to remove a socket for you so you can see how an RFC is wired.
I just counted the cables in the diagram that Spark123 posted.No id expect continuity but that still doesnt mean only one cable at each socket there are two physical cables at each socket in a RFC, count them if you dont believe me.
Agreed.if its worded as you say then i dont know why you can use purely the cpc in the twin and earth.the reg implies this is not enough surely.
Good question.i know we all do it but is that reg is wrong,or we are installing it wrong.
