MAGNACLEAN FILTER QUESTION
It is clear you are intimidated by my knowledge.
You put it down to what you like.
That is what it is. You show no constructive views, only take matters to personal levels and are quite a negative person. Maybe you were not chastised as a child :)
Your contructive views bear no relevance to any OP, nor is it intended to help them. Their only purpose is to make you look like an innovator (which you are no more than Simon Cowell is). Indeed I never see you helping anyone on any repair/breakdown threads.
Your contributions are always based on theory because you have no experience of practising any of what you preach.
Magnaclean Schmagnaclean. :roll:
It's no more expensive, give or take a handful of quid, but it has the advantage of filtering the crap out instead of leaving it in the system.
A plate plate exchanger is a is a plate heat exchanger.
That's exactly what a bullsh*tting charlatan would say (especially if they said it in the form of a rap).
And I'm still not really sure if the government should legalise DIY gas work, or leave it illegal, like it is now. What do you think, Bigsystems?
When is a 100 kW plate heat X not a 100 kW plate heat X?
What has this to do with the thread? Have you been drinking?
When it doesn't have usable connections, or methods of support. Most combi ones wouldn't be any good.
