- Joined
- 28 Oct 2005
- Messages
- 31,236
- Reaction score
- 2,001
- Country
[quote="roughcaster";p="939049"]If you can't make good a scar/blemish with multi finish one hour into it's life Joe, that's your problem, I can, others would probably agree i'm sure. You certainly can't spread with it, but it is far from set (solid) overall. Setting time for multi finish, one and a half hours,,, approx,
Again "Joan Intie", read the feckin post properly. I said that you cant spread with one hour old multi finish, but it is NOT set,,,,,, and if thin fibre glass mesh tape is stronger than jute scrim, why do they reinforce plaster mouldings and cornices with jute scrim? fool.....You make all these comments about other people on this site people, whom you don't know,with nothing to back up your claims, except twisting words and phrases to make it suit what you want to believe, a total a**e hole........ Let's go again Trigger, giddy up.
Roughcaster.
Fibre glass scrim is far tougher than jute, but I guess you've seen neither never mind worked with the stuff. The reason they use jute is that it is floppy and bends easily (bit like you according to your missus) but it isn't anywhere near as strong. You ask Noseall.
