ok i give in where do i find a 12v ac relay?
19 Apr 2004
Can you help me solve this one?
I have an existing doorbell with 2 ringers (3 storey house), that is mains powered (12v ac transformer)
i want to add a second ringer, only i want it to be wireless for in the garden, so i've got a wireless push and cordless ringer, and disassembled the push, soldering on 2 wires either side of the switch.
in a vague attempt to get something to work i tried a 12v dc relay, which kinda works (makes a light flicker), however the relay switch isn't long enough to mimic the doorbell push.
so any ideas? suggestions?
Are you handy with a soldering iron? You could make a little rectifier out of some diodes so the DC relay will operate on AC
Your half way there already.
Try this....
Feed the relay coil via a small bridge rectifier..
Across the coil connect a suitable capacitor (about 100mfd) that will hold the relay on for half a second or so to allow the wireless system to work.
sounds more complicated than it is but It's all I can think of.
Regards FB
maplin
OR you could get a 4001 diode and put it in series with the rlay you have (maplin sell those too)
I reckon one diode in series and a cap across the relay would be the minimum for a dc relay . Doesnt really need a full wave rectifier.
Or just get an AC relay :roll:
Even my wholesaler stocks them - The type that plugs into a din-rail mount base....
If memory serves correct I do remember 12V AC were not common at electrical wholesalers but electronics ones gen stocked them.
If you do use the DC one with diodes(s) you will either get a reduced or higher DC voltage, if higher and it`s past the coil spec voltage then calculating a series resistor should protect the coil, a cap accross the coil will help smooth the voltage too
with just one diode the differeance is neither here or there.
with 4 diodes (bridge rectifier) the voltage drops slightly. if you then put a smooothing capacitor on it the voltage is multiplied by around 1.5 times.
put 1 diode on it will be the best option
the octal base relays are not good idea in this case, they tend to draw a lot of current (for what they are) which most door bell transformers can not supply.
Gents, many many thanks, there's a wealth of knowledge far greater than my own!.
I'm very happy with a soldering iron, however i confess talk of capacitors, rectifiers and the like sounds complicated to me, i've been searching high and low for a suitable ac relay, which is what led me to post here, an ac relay would be my favoured solution as i think i can suss that out.
so on the basis that i can't find an ac relay it seems diodes and a cap are required, so for the pure layman, does anyone feel inclined to give me a detailed shopping list and perhaps a diagram?
Many thanks
Pete
IN4001 diode in series with the relay you have. done cost 12p
see the link i posted earlier
(maplin part number QL73Q)
Folks thank to one and all, the diodes as a bridge rectifier thingy did the trick, chuffed to bits, thanks again
regards
Pete
You don't even need the relay. I've had a setup similar to this for several years. Short out the switch on the wireless pushbutton and feed its power supply from the voltage across the mains-powered bell via a diode, resistor, zener and capacitor. No relay needed and no battery to go flat in the wireless sender.
