Hi Everyone,
I would be most grateful if someone more experience then I would be able to assist me with the following matter.
I would like to install low voltage lighting under the front canopy porch soffit and also some new driveway path lights leading up to the house. On approaching the house I would like these all to be switched on by an outdoor PIR sensor.
Is the wiring circuit diagram I attached here the right way to connect it all up?
View media item 3744
I have used a junction box for the drivelights so they are easier to connect which will mean that I don't have do any chasing in the external walls as the wire from the sensor to the junction box will be inside the house.
Also where in the circuit can I connect a switch so that I would be able to reset the PIR sensor. What wires connects to what regarding the switch?
Any help will be most appreciated.
Thank you for your help,
Stephen.
[/img]
Stephen.
[/img]
