You have not stated the size of the tank so it could well be big enough.
Why not install them and do a flow test, I would guess that the jets you would get 4-6liters per min from each and the head depending on the size and the type lets say 8" modern rub clean type 14- 18 liters @3.0 bar.
You have plenty of hot stored water so share it out well.
There are always good solutions to getting a good system design.
Eg
Basins flow restrictors to 6 liters per min
kitchen tap 9liters per min
bath unrestricted unless could be used at same time as shower then restrict to 18 liters per min assuming you have standard size bath.
By doing this you will have enough water for your shower even when the missus decides to wash up.
Remember that pressure and flow are not related.
I am not sure why you are worried about the pump coming on as that is what it is designed for all you want to achieve is it not cycling on off quickly as this will hurt the pump. but you will want it to react else you will turn on the shower and then it will die a bit then boom your big boy multi-stage will peel your skin off.
Eg
If you reduce the pressure but still use 12 liters per min then the pressure will drop faster than if you use a flow restrictor @ 6liters and the pump will come on quicker.thought i'd use pressure adjustable reducing valves as you can set them easier to 1bar in order not to trigger the pressure switch on the pump however if you think flow restrictors would be better then i'll consider it thanks,
