I have a Potterton Prima 60F Central Heating system - simple heating system with 16 rads each with TVR so no room stat. Had problems with air in the system for a number of years. As the system worked OK I just bled a number of radiators weekly to remedy problem.
12 months ago I had to replace the pump and since then the system has ran very noisily after a couple of hours ie loud running water noise round the pipework in the airing cupboard - this is a new noise.
So after discussing on this site was advised to get rid of air problem first as it looked like my pipework arrangement could have been causing air to be sucked into the system via expansion tank. Recommendations included lowering horizontal pipe above pump ie increase static height plus increase its length so the pump would not be pulling directly on the feed/expansion pipe.
Pipework before mods
The 2 pictures below show new pipework arrangement. On the picture showing the pipework going into the loft - expansion tank, I decided to create 2 right angle bends enabling me to not change the siting of the tank connector. Could this be the reason why I am still getting air in the system?
[/img]
[/img]
