Blinking neon ceiling light
6 Apr 2015
Aberdeenshire
Does a blinking neon round ceiling light indicate a new tube or fuse is needed. Also,
how do you expose the tube beneath the casing. I notice a small button which doesn't easily press either in or out. Thanks in advance.
Neons in switches are not replaceable and some blinking is quite common and nothing to worry about. ;)
Neon signs
Another skill based art form being lost and replaced by LEDs
The people who bend the glass to form those signs are skilled craftsmen and women.
You need to either upload and post some pictures and link us to the unit you have. It is unclear what you are explaining.
I guess this is possibly a fluorescent light?
With regards to how to remove the cover or diffuser, would depend on the type you have.
If a fluorescent tube is blinking it 95% likely it needs replacing.
If it's something like this:
then the tube AND starter should be replaced at the same time.
To remove the glass cover, the metal bit in the centre usually unscrews.
Another completely wasteful and unnecessary practice. Starters are generally reliable and do not need replacing with the tube.
I'd rather 'waste' 25p on a starter because the alternative is to be called back to a customer because the old starter had failed a few days after fitting a new tube.
But this is not a customer calling out a sparks, it is a DIYer. As such he possibly does not know which of the various types of starter to get.
Several times I have been asked for help after a wrong type of starter has been fitted.
He doesn't apppear to even know what type of light fitting he has. He isn't going to need a starter for a NEON ceiling light!!
Yet again. I am going to await a response from the OP before hurtling off down many cul-de-sacs while thowing wild suppositions that are based on no facts.
Yes, it does look like the circular fluresent picture that's been posted. So do I need need both a new tube and starter? How does the unit open? Thanks again chaps.
