I either under light or over light. I have a L shaped kitchen (west facing) on the main bit over the cooker/sink currently has 3 leds (which are a designer brand nightmare as cant get the bulbs to fit) and 2 LEDs on the entrance bit. Its too dark. I have too many dark spots not sure if not helped by using spots. There are no lights under the counter either.
I cant use white fittings as sadly attracts flies and fly poo. Only option is brushed chrome and timber. I want something that looks classy, not too ikea-ish and not dated. Something quality over some that are so cheap Im not sure how robust they are.
Is it better to go for old fashioned bulb fitting set - if so how many bulbs? Using LEDs would 4 bulbs improve it a lot and 3 over the other side. I also spend a lot of time in the kitchen so the light needs to be perfect and not overpowering.
I find this a minefield I can of course incorporate a dimmer switch.
