Hello, I've bought a flat and it has three hidden fireplaces. All of the walls are freshly boarded and plastered and the walls look quite thick. I didn't know there were fireplaces until taking the flooring up and seeing the hearths.
I've also now noticed a damp patch at the base of one of the fireplaces, not on the face of it but on the side, and just one side. It's about a 20cm tall patch.
I've been reading about the fireplaces needing to be vented but have no idea if these were and have no access to the floor above (I'm in the ground floor flat of the house). There are chimney stacks and the surveyor recommended that they get capped and have flashing repaired.
So I'm wondering if I should just drill a few holes into the damp patch to see what's behind the plasterboarded walls, or just go into the face of the fireplace and see from there.
What would people recommend?
I can't see damp around the other two fireplaces (which are either side of the same wall) but should I drill into them anyway?
I'd like to avoid having to do too much work, if I open up the plasterboard and there is an airbrick, would it be a matter of just putting a vent on the plasterboard?
