Hello
Trying to plan the layout of envelope tiles on a wetroom floor. It’s an Impey Aquadec Easy fit with 4 envelope cuts. I’m using 20cm tiles.
Am I right to start laying the from the drain outwards? I’ve got the drain equidistant from two cuts, which is as good as it gets with an eccentric drain.
It means the long sides of the room will each have an 8cm tile, which I guess balances it.
As you walk in the toilet is directly ahead with a window above it. The toilet and window share a centreline but the tile layout won’t fit with the centreline. Is this something that will forever draw the eye or am I overthinking it? Sorry for the basic sketch below. The drain is red, the WC centreline is green. Thanks
WC
Door
WC
Door
