Old House Mystery: 6-Bell Servants’ Call Box – 2 Still Missing, Any Ideas?
Without knowing exactly that the products are it's fairly likely they are low resistance solenoids and bell in series, that was certainly a popular system.
They typically, ran from an 'accumulator', then later a bell battery. Pressing a bell push, energised a relay, which unlatched a flag, which then 'waved' a flag, in one of the windows, as it rocked, and rang a bell. The flag would then need to be reset, or latched, via a manual reset button.
That doesn't appear to describe this one, I dont see any reset/release mechanism so I think it's the type were the solenoid pull the flag to start it swinging- I'm not there to inspect it so very happy to be corrected on this - as such it tends to require a greater magnetic flux and greater current hence the lower resistance.
You are correct - it's the basic model, rather than the deluxe latching version ;)
Must admit I do appreciate the ingenuity of old techniques, some of them were very clever too.
A joy to behold.
Some of the famous builds of the old engineers Like Brunel to name just one. the mechanical and electrical disciplines of old were really imaginative and I commend them alongside modern stuff like the Moon landings and the Falkirk Wheel.
Oh I could name many many more both ancient and modern.
The London Hydraulic Power Company.
It may not be as low current as you imagine, the wire showing looks like it might even be modern 1.0mm² T&E, I'd be tempted to not deviate too far from there.
Yes, that's how they were usually wired, each button connected to one solenoid and the common of all solenoids wired to the bell. Last year I built a working late-20s setup (original transformer, bell, panel) on my bench as a demonstration. The panel was much less ornate than this one, just a plain steel box painted black. The wires were something like 0.5 mm2 solid cores, rubber and cloth covered.
Those bell transformers are usually 1 A so I'd expect the current to be no more than that. I've been taught it takes more than 300 mA at 230 V to start a fire (70 W) so I wouldn't be particularly worried about 12 V/1 A on an isolation transformer.
Re the required wire thickness, I once had a ding-dong doorbell that was connected to the button by maybe 20m of telephone-type wire, and that had enough resistance to reduce it from dong-dong to just donk. I fixed that with a transistor. If you plan to reinstate the missing buttons here, I'd use something similar to what the other buttons have, not thinner.
I`m trying to remember an old domestic signalling system that was deployed in old houses (mansions with servants probably) and if I remember correctly it caused a number of compass needle to point one way or the other on a marked lattice to signify which phrase or letter of the alphabet was signified.
maybe six wire to signify the whole alphabet or some such.
I might be a bit out with those number but I`m sure you get the drift.
Why the heck Lord and Lady Posh People could not simply open a door and shout to Jeeves the Butler or Connie the Cook like us ordinary folks might do, I dont know.
But it was somewhat ingenious nonetheless to see a diagram of it as a young boy.
Some hospitals.
Indeed these thing are quite hungry
