- Joined
- 7 Sep 2025
- Messages
- 252
- Reaction score
- 16
- Country
Do you think they will run on linux?This is what I would do ….download an app like Fing or network scanner
This is what I would do ….download an app like Fing or network scanner ….check what’s on your network , it should give a list of all,devices ….make note ….now connect camera , hold in reset and power up ( this will probably default ip settings and it should pick up new ip address…give it 5 mins …now re scan with Fing ect …there should be an extra IP address listed , take note …type in the new address in web browser …with a bit of luck it should bring up a log in screen ….then go from there…
What is a net work scanner?No need....
If the OP uses a PC, which doesn't have a designated IP setup, then all he need do is connect it via a LAN cable to the camera, and scan, using a network scanner. It should find the camera's IP.
are you sure?seems it does :-
- Compatibility: It is available for various Linux distributions, including Debian, Ubuntu, CentOS, Fedora, and Raspbian.
But I dot know of ay that run on linux. Unless you do that is?A piece of software, that scans, a range of network IP's, to see if it can get a response. IP scanner will do what you want, but you will need to make a guess at what IP range to scan - 192.168.1.0 to 192.168.1.100 might find it.
Why?But the picture quality is going to be shhhhiiiiiitttttteee
Do you have any links to any cameras and dvr's (what ever that is?) for around the price mark you mention. That you know of, that are of sound working quality please?If you cant sort out the network side then I wouldn’t bother , you can pick up a 5mp waterproof camera for around £20 and probably a cheap dvr for around £100..
Is this the kind of thing that you had in mind?If you cant sort out the network side then I wouldn’t bother , you can pick up a 5mp waterproof camera for around £20 and probably a cheap dvr for around £100..
