2 storey side extension
21 Jan 2026
I am planning to have a 2 storey side extension built but the internal floors of the cottage and outside dpc are almost the same level as the surrounding ground outside. Will this cause a problem regarding dpc building regs when the new extension is built? How can the new extension floor match with the cottage when the new dpc should be 150 mm above ground level?
Make sure the damp proof membrane goes up the wall to tie in with the dpc.
Or lower the ground, add drainage.
Does it cause you any problems at the moment?
There doesn't appear to be any damp problems at the moment.
Any modern cavity construction, can be built to mitigate high external ground levels. BC will likely want to see FFL rated masonry at least 150mm above ground level externally. Your designer should be aware and design the building accordingly.
