Hikvision doorbell camera
15 Nov 2009
Lincolnshire
Currently got three wall cameras which worked fine, all just plugged into the NVR and using a screen and mouse (no PC involved) all seem to have work including on the hikvision app.
I bought the DS-KV6113-WPE1(C) doorbell camera, and can’t seem to set it up.
Watch loads of videos, so downloaded SADP tool, where I can see the camera but when I use the DHCP it doesn’t do anything to find a new IP address. I manually put in an IP address (the next number along, in line with the other three cameras). It then says to double click the IP address which takes you to the hikvision web access, but doesn’t. But in fairness if I double click one of the other three cameras they don’t too.
I then downloaded ivms-4200 as per what the videos were saying.
I can see the other three cameras, but not this one.
If I go back to just using the screen again, I can see the other three cameras but not this one.
I’ve been trying all day and getting nowhere, is there anything else I can try?
It’s hard to say, as your following things properly allegedly but I can’t see where things are going wrong for.
Device is powered and paired onto your WiFi?
From SADP tool you should be able with the password set the ip address and gateway.
Is the problem you can use on hik connect but can’t get it to work on the NVR?
Do you have the indoor station also?
Been a while since I last did one, and recall there were a few issues, setting it up when on the customers site.
Getting onto the M series NVR was difficult, and had to do a lot of faff even had Hikvision support login to my laptop on site, I was lead to believe these issues were addressed some time ago now mind.
Thanks for your reply
To answer your questions-
The NVR is plugged straight into the router using an Ethernet cable, the laptop is using WiFi from the same router. The laptop is plugged into the back of the NVR via an Ethernet cable along with the 4 cameras.
I can’t see the new camera on the Hik-Connect, the NVR screen or ivms. Only on sadp.
Sadp is not choosing a new IP address. I can only do it manually.
I do not have a door station as apparently this model doesn’t need one and can work directly with hik connect.
What IP address are you putting into the door bell ? As the plug and play cameras may have an address that’s not your routers address range
I am just putting the next number along from the last camera ie
Xxx.xxx.xxx.2
Xxx.xxx.xxx.3
Xxx.xxx.xxx.4
One thing I did notice was on the other three cameras the gateway was 0.0.0.0 but when I change the doorbell one to the same, it didn’t like. it so left it at 192.0.0.1.
The only other thing I’ve noticed was the other cameras had 8443 under ‘enhanced SDK service port’ but the doorbell just says N/A.
Ok is the ip range one of these for your existing cameras
192.168.0.0
192 .168.1.0
These are the most common ranges for most home routers , the cameras if plugged into a POE dvr with be completely different , you need to address your door camera to one of your router ranges eg 192.168.0.250 , then set one of the channels on the dvr to use your router range ( in other words it’s not using a plug and play address )
As an example
Yeh your doorbell is not connected to the NIC of the NVR like the other cameras, this is not accessible from the home network, u need to address it on the LAN, then add it manually on your NVR which is connected to the LAN
If you run CMD and type ipconfig on your pc u will beable to see the ip adress of your computer, subnet mask and default gateway. U will need to give the doorbell an ip on this range with the subnet and gateway the same.
Ive tried again. Did the ipconfig thing.
LAN - ***.***.**.111
Nvr is the same but with 112 at the end.
So put the same with 113 at the end. Subnet and gateway the same.
Double clicking the IP address on sadp doesn’t take me to the hik vision site, but does when clicking the nvr ip address.
On the nvr itself, changed ‘ Poe setting’ ‘Poe binding configuration d4 to not emabled.
And on the ip camera page, changed d4 to the same ip numbers as above (113).
But still getting the same error.
Because the IP address didn’t take me through to the hik vision site, I haven’t put a password on the camera. Could this be the problem?
Also when looking at the nvr details. Enhance SDK service port, ipv6 address, ipv6 gateway, ipv6 prefix length are filled in. Should I be putting any of these into the doorbell ip details ?
No.
Using SADP put in their address you want, the gateway being used which you should now have.
Use the doorbells password and the io address should change.
If your still struggle give us a bell tonight after 8pm and take a quick look remotely for you.
I
When you say doorbell password, I never set a password for it, I take it if you double click on the IP address it should then it takes you to the hik vision Site where I set a password but I’ve never got that far.
So you have set the door bell at ending at 113 ?
from web browser enter ip address ending 113 it should bring up a web page for the door bell
