Bathroom vanity light. New lamp but not working.
20 Mar 2004
I had a power cut yesterday and today my shaving light (as in pic) wasn't working. Don't know if there's a connection or just coincidence, everything else in the house is back to normal. Bought a new lamp and refitted the cover (lamp won't work without cover) but - no light. All the switches on the board are 'On'.
If relevant, new lamp is LED (old one wasn't).
Can anyone suggest what my problem is? Many thanks.
Can't say about the shaver as I don't have anything 2-pronged.
Fred, can you tell me any more so that I'm fully informed when I go back to CEF? Thanks.
Post #4 of this thread may be of interest. I'd still like to be 100% sure of myself when I go back to the shop though.
^^^^You have to click on thread title beside the circular photo (I only just worked that out)...
Is the old lamp a clear glass one?
In which case, can you see if the filament is intact?
If so, try refitting the old lamp. Make sure the lamp caps are making good contact with the terminals. Some fittings have pieces you have to slide back and forth when removing and refitting the lamp.
Also, make sure the cover is fitted correctly as often there are safety switches that need to be closed. These are activated by the correct location of the diffuser, without this, the unit won't work.
