Hi There,
Any advice here would be greatly appreciated.
I basically have my whole loft floored already from when i moved in my house. I have a ten year old house with a fink truss (W frame) roof style. The property is a mid terrace and at each end of the party walls there is some plasterboard fitted and the roof has some cladding attached horizontally to seperate the space from the roof felt and tiles. I assume the previous owners wanted this to be a clean storage area of some sort.
Whilst our surveyors clearly didn't venture into the loft as there is no planning permission for such work i am wondering if this will be problematic for me in the future if a surveyor for a future buyer did have a look up there?
From trawling through all posts about loft flooring i have also came to the conclusion that the loft flooring might not ideal in it's current placement (attached straight onto the beams) My issue is with the potential problems with moisture etc from not having a good air flow under the boards. From what i read it seems to be a better idea to have the loft flooring on top of counterbattens.
Now, i am happy with the loft flooring as it serves a purpose. I have a couple of questions relating to this.
Would there be any benefit in raising the walkable part of the loft only and counterbattening (too much work to do the whole lot) whilst leaving the other sides the way they are?
If i was to counterbatten the central part of the loft floor do i need to have batten that stretches for the full length of the floor or can this be done in sections (dont know if i would get battering long enough up there.
Is the work done to each end (plasterboard attached to 2x2 with rockwool inbetween and the cladding to the ceiling) going to cause me structural/legal problems?
Basically, i like the work done in the loft and i would prefer to keep it, albeit i want it to be as safe as possible
Thank you for any assistance
Cheers
McLean
Cheers
McLean
