- Joined
- 11 Jan 2004
- Messages
- 46,943
- Reaction score
- 4,021
- Country
Yes. Could use 2, but there appears to be a ridge on one side preventing this.Is this the sort of thing your looking for but 20mm? (could you use 2 of these?)
I have only used PVC spacers where you need to fit an accessory that needs a deeper box than is currently chopped into the wall and for whatever reason you're unable to cut the wall out ie UFH thermostat, dimmer switch on a 16mm box etc so I assumed this was the same scenarioI'm just curious - assuming, as seems to be the case, we are talking about a surface-mounted 'pattress' box, why can't it simply be replaced with one of the required depth?
Indeed. I suppose it's the "whatever reason" that I was curious about.I have only used PVC spacers where you need to fit an accessory that needs a deeper box than is currently chopped into the wall and for whatever reason you're unable to cut the wall out ie UFH thermostat, dimmer switch on a 16mm box etc so I assumed this was the same scenario
Perhaps he is being polite: You Try Looking Please?
After all, you obviously did not even make the slightest attempt at using the internet to discover if your statement was accurate before posting it.
Are you saying I post inaccurate stuff?
After all, your statement was accurate before posting it.
It's easy to work it out.
He's a troll.
