- Joined
- 22 Apr 2018
- Messages
- 124
- Reaction score
- 3
- Country
Looking at that eyesore of our CU, I noticed that the RCD (which protects only kitchen, upstairs and downstairs rings) is rated for 60A when the circuit breakers are 32a each. Is that a problem? I am aware that it is unrealistic to have 3*32A=96A at any given moment, but it is theoretically possible.
What would happen to the RCD in that instance? Does it get damaged, or will it simply trip when the combined load on the three rings go over the 60A?
Secondly, all of our lighting circuits, cooker, fridge and boiler are on the CU section w/o RCD.
I am a bit surprised as I just stumbled somewhere on the net saying that if a lighting circuit is buried less than 5cm into a wall, it needs RCD.
We just had our kitchen done and the leccy hasn't brought up that point and our wiring are definitely within 5 cms of the walls (if anything, there's cables going down to our new switches); they are within the safe areas though, as I could observe during installation.
Is the fact that the wiring sits in the safe areas trumping the need for RCD?
What about cooker and boiler? Wiring for these also sits in the safe areas.
If it helps with regs, our installation is 20ish year old by the look of it.
