12v x 20 amp switch required
15 Dec 2009
Whitby N Yorks
Hi, I need a 12v 20a switch to fit into/on/through a 16mm wood panel. It is not possible to make the panel any thinner.
Any suggestions appreciated.
Mike
Toggle, rocker or other type?
If it's a toggle required, the front face of the timber can be counterbored to accept the nut.....a rocker switch will grip in the rectangular hole required but may need a spot of adhesive to keep it tight.
Maybe there are other surface mounted types available?
John :)
Will that one accept DC? I thought most AC switches weren't rated for DC due to the constant arc on breaking.
