Thanks for the replies. I used Kevs radiator calculator and came up with a figure of 49,000 btu's(new wet system) to keep all my rooms including the loft conversion at 15 degrees with a 1 degree drop per hour. Checked my existing boiler and warm air side is 31,000 btu and hotwater side is 11,500 btu's. That would put me around 85,000 btu's for the new boiler as i have roughly doubled up my requirements.(Is this an alright way to do it or am i missing something)?
I was planning on running in the pipes myself as i can't do anything else with my loft conversion until they are in. The boiler itself i wouldn't touch as i know my limits. So 15 radiators, 85,000 btu boiler, 2 zone valve to seperate upstairs/downstairs and a unvented hotwater cylinder(150 to 200 ltrs), radiator ring main in 22mm and dropping down to 15mm off the T's to the radiators themselves? Is that OK? On the mains water pressure side there is plenty. For example in the bathroom i've got one of those telephone handset bodywashers T'd off the bath taps and it's hooked to mains and will practically jump out its cradle when turned on quickly.
