The current carrying capacity of a given cable type depends on how it is installed i.e clipped direct to a non-metallic surface, touching thermal insulation on one side, running in thermal insulation, grouped with other cables, the ambient temperature and the type of protective device.
One of the factors is, can heat get away when it starts to warm up (as it will when carrying a current).
So is it hanging in the air? Buried in insulation? Stuffed in a duct or conduit? Bunched with lots of others? And if so what current are they carrying? On a cable tray? Buried in plaster or concrete? Passing through a sauna? Next to hot pipes?
