I am replacing my standard hanging light in the landing with 240v spotlights using GU10 LEDs rather than the normal GU10 Halogen.
I have one switch downstairs in the entrance hall and the other one upstairs in the landing.
My problem is that when you switch the lights off the LEDs have a faint light (i.e. not 100% OFF) and when you switch the lights on the LEDs lights up to the normal brightness (i.e. 100% ON).
It is all wired up and double checked (actually triple checked) according to this wiring scheme,
If I replace the LED with Halogen bulb they remain off when lights are switched off.
I also disconnected the cable to the downstairs switch and replaced the upstairs with a 1 Way switch and that works perfect when using the LED bulbs i.e. 100% OFF and 100% ON.
I am running out of ideas here so any help would be appreciated!
Thanks!
Thanks!
