Couple of easy options:
1 Use an impulse relay- dumb switch becomes push to make, rf switch needs same functionality.
2 Some WiFi power controllers have a local on/off button on the case. Extend that button to your ptm dumb switch.
You don't.How do I turn a standard toggle switch into push to make?
You don't alas. You either keep the original switch & tell users to switch it on then off again for function or (if it is a 1 gang switch) buy one. If its 2 or more gang you'd have to go to gridswitch or similar.
Is this a real RF setup you're going for or WiFi smart switching type thing? There are loads of WiFi smart light switches that can run without a neutral..
You don't.
However you can put a regular switch and a push switch (reffered to as a "retractive switch" by UK electrical accessory vendors) on the same plate using a modular range. Scolmore click has the nice feature that their regular lightswitches are built from thier modular range and yet the preassembled switches are priced to be competitive with other brands non-modular products. This makes the total cost of an assembly considerablly cheaper than with brands whose modular range is seperate from their regular range.
If you buy
https://www.toolstation.com/click-mode-10a-switch/p10481
https://www.toolstation.com/click-mode-grid-module/p43236
Then you can just unscrew one of the regular switches from the back of the plate and screw on the retractive switch.
Thanks buddy but it seems like an expensive solution for something that doesn't have WiFi functionality.One of these at the switch: https://www.tlc-direct.co.uk/Products/LMEST1.html
can be used with any normal on/off switch, not necessary to obtain special switches.
and this receiver unit: https://www.tlc-direct.co.uk/Products/LMESR1.html at the light or whatever is being controlled.
Hmm. This socket-is it on a ring final (or is the socket switched from somewhere else)?
Actually, a more comprehensive description of what you have now & what you're trying to achieve would be helpful...
