2 gang switch to control 2 lights
So he'll need to get access to the JB, and under the floor to run the cables to the lights.
Indeed.
He could just as well access coiled up cables from the switches, and run them to the lights, and end up without any joints.
He could, but (a) he'd have to coil up an awful lot of cable if he has no idea where the lights would be and (b) as sparkwright has just reminded us, he apparently only has small conduit in situ to the switches, which presumably could not accommodate the two cables that would be required if power were to be looped through the switches - so there would then have to be supply looping through the lights.
Kind Regards, John
Not sure where this discussion is going. .. The point of the post was he wanted to re-use the narrow switch conduit,
hence why he wants to use a 3 core and earth cable (again), so he won't be 'feeding' the wall lights directly from the switch.
Indeed - I'd forgotten that. Provided the big JB can remain accessible, I see nothing particularly wrong with what the OP originally proposed. A good few moons ago, I had such an arrangement for most of the lighting in a previous house.
Kind Regards, John
