Evening all
Im hoping you can help me with the 2 problems i've got.
1, We have noticed that when the hot water is on only the rads are getting hot. Room stat can be set to 0. ch off on timer. this does not happen every time. Been pointed in the direction of the 3way valve. How do I test this. Its a danfoss hsa3 and is about 3 years old.
2. This has only happened about 10 times so is very hard to try things. In a morning we get banging sound from the pipes in the cupboard. I have managed to test a few things and it seems that the boiler is coming on but the pump is not. If left it all shuts down and trys again later. If I switch the system off and then on this clears it and all works. As far as I understand the pump should start first to get the water moving them the boiler starts and at the end the boiler goes off and the pump runs on for a bit. What could cause this? What controls the pump? When the pump is running it sounds normal.
Lee
Lee
