Hi, we are having 2 problems with our relatively recently bought (second hand) Mondeo. It is an '05 diesel estate with just over 80,000 miles on.
Up till now it has been running fine apart from a bit of a squeak from one wheel occasionally, but now 2 problems have appeared:
Firstly, the airbag warning light and brake warning light have been coming on and off intermittently (when the handbrake is off). Sometimes they are both off for a while, but then one or the other (or both) will start coming on and off for a while "disco lights" fashion. Neither stays on for any length of time and we haven't had any obvious brake or airbag problems, which makes me wonder whether it's an electronics problem rather than actual faults.
The second thing is that it's been having intermittent problems starting. Sometimes it starts first time with no problems, but other times it makes a loud whirring noise when the key is turned, but the engine doesn't kick in. The electrical stuff (radio, dash lights etc) all come on as normal. Usually after trying it a few times, putting key in and out etc it will eventually start normally after 3-6 attempts, and then runs quite normally once it has got going.
I can't see any obvious link between the two problems, and they don't necessarily seem to happen at the same time, so not sure whether there is any connection or we are just unlucky to get 2 faults at once.
I think it's going to need a trip to the garage, but would like to be a bit more clued up on possible causes and solutions before taking it! So any advice would be gratefully received.
