2-way dimmer switches
15 Jul 2004
The old topic again:
I have installed 2 2-way dimmer switches to a couple of mains voltage halogens wired in series.
The switches work fine and I can switch the lights on and off OK. When it comes to dimming the lights at the mid-points in the range the lights begin to pulse and don't stabilise until full power is reached. This is the same whichever switch you dim.
Does anyone have any ideas or should I just replace one of the dimmers with a standard 2-way switch?
First of all, I hope the fittings are wired in parallel, not series. Do a seach on both words to help you.
Second, if you have put a dimmer at both ends of a two-way lighting circuit, it is no wonder the circuit is playing up. You cannot do this unless you have dimmers specially designed for this job.
You should have only one dimmer and one plateswitch on any one two-way lighting circuit.
tlc supply them, but take this advice:
you will be getting a lot of grief if you do, check these forums for problems wiring them
